What is causing my uneven tire wear?
Google
Web AF
barty_10
08-08-2006, 10:29 AM
The inside of the passenger front tire on my Tahoe is wearing badly. What would cause this? All my other tires are wearing normally. My oil change facility said it is simply the alignment. Are there any other causes of uneven tire wear on 1 tire only?
Thanks
wrightz28
08-08-2006, 11:42 AM
If it's just the inside of the contact patch, it would sound like the camber is off, either by a loose/broken/worn strut or mount/bearing assembly or ball joint failure.
gw84
08-10-2006, 01:56 PM
bent rim. Have you curbed it lately?
Young Chuck D
08-10-2006, 11:04 PM
incorrect tire pressure, bent rim, misalignment, shitty suspension... take your pick
Google
Web AF
