Engine Light for a few seconds on a full tank of gas?93 Freshcort 08-08-2006, 06:26 AM This has happened a few times in the last couple of weeks, but after filling my tank with gas my "Check Engine" light will come on but only for a few seconds and then it goes back off again. Anyone have any idea's?? Thanks 12Ounce 08-08-2006, 08:22 AM Given the symptoms you give but no codes, I would guess something about the EVAP system is getting flacky. Could be just the gas cap. But before buying a new one, I would look all the hoses in the engine compartment that go from the engine intake manifold, thru a valve and a sensor, thru the carbon cannister, and back to the hose/tube connection at the firewall (that leads back to the tank). You will likely find cracks and holes throughout this hose, as it is not a very durable material. Hopefully you have not already sucked debris into the valve or the flow sensor. You'll probably have to remove air filter cannister to get to this area. Automotive Network, Inc., Copyright ©2012
