Steering Wheel Radio Controlsvalivin2003 08-07-2006, 03:18 PM All of a sudden the radio/climate control controls on my 95 Riveria are acting crazy. If I hit volume up, for example, volume doesn't change, but after a few seconds the band changes, then the station changes and the temperature control changes. It does not matter which of the controls I push. None work. Dashboard controls all operate correctly. 1. Any ideas? 2. Can I replace the steering wheel control module? 3. Anyone know where I can get one and/or how much they cost? Thanks!!! Blue Bowtie 08-07-2006, 11:24 PM Ouch. The only one of those I ever worked on was a '96. It ended up with a new steering wheel pad. Hopefully, you'll have better luck: http://72.19.213.157/files/RivieraDashDisassembled.jpg The gray cable from the steering wheel pad is a multiplexed signal, decoded by the radio head. If you're lucky, the cable is damaged and can be repaired. valivin2003 08-08-2006, 09:59 AM Thanks very much, especially for including the picture! Your info is very helpful. I'll check out the cable and hope for the best! :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
