Stereo Woes
Google
Web AF
DMod
08-06-2006, 08:57 PM
I just got a 92 Lumina and it had the radio ripped out (and the stock harness cut). So I decided to throw my cd player from my old car into this one. I am 100% positive I hooked it up correctly, but the thing wouldn't turn on. So I hardwired the power to the fuse box and hooked up the speaker wires correctly to the cd player, and now the player turns on and functions, but I get no sound from the speakers. I have no clue what is going on but it seems that the original wiring is shot. I am completely lost as to where to go from here. Some help would be greatly appreciated.
smallbrady89
08-06-2006, 10:05 PM
i would try different speakers. like if you have any lying around. and wire them to the radio without mounting them just to see if they work. that will narrow it down a bit. if the test works then its probly a problem with the wireing. either shorted out somewhere, cut or maybe the speakers are just blown.
tblake
08-07-2006, 01:07 AM
what kind of lumina? are you sure it doesnt have the bose amp in it from the factory?
DMod
08-07-2006, 09:15 AM
It's a 92 lumina Eurosport. I am pretty sure there is no amp in there.
tblake
08-07-2006, 11:18 AM
euro? Are you sure there was no factory amp? take a look at the speakers in the door? have they got bose written on them?
tblake
08-07-2006, 11:36 AM
my sources do show that your car May or May Not have an amp in it. It says that its under the rear shelf in the trunk. If yours does in fact have an amp, you may have to wire things up a little differently to your radio.
tblake
08-07-2006, 11:40 AM
it appears there is a pink wire that is the "turn on" for the amplifier. It needs to be hooked up to turn on the amp.
DMod
08-07-2006, 12:27 PM
I appreciate all the help guys! I finally got it working. Apparently there was a short in the wiring. Once I spotted it and re-hooked everything up I was able to get it working! It's amazing how one little thing can cause you 2 days of headaches :banghead:
Thanks guys!
Google
Web AF
