Solid Axle Conversions!!
Google
Web AF
DSA-STEEL
08-18-2002, 01:07 PM
GO HERE IF YOU ARE INTERESTED IN A SOLID AXLE CONVERSION.
http://www.allprooffroad.com/suspension.html
:flipa:
yunaderis
01-14-2003, 11:34 PM
yeh right
this is the best place for tacoma solid axle swaps
www.toy4x4.net
trdvet
01-14-2003, 11:35 PM
I wouldn't, he is changing his design, the one on that Tacoma wasn't even tested and they are scrapping it. Later :finger: :finger:
§©RÉWßã£
01-19-2003, 08:57 AM
...Here's the trick.
Go find the axle you want to use....
then find the springs you want to use.
and figure out how to put them on the truck!
buying a "SOLID AXLE CONVERSION KIT" isn't the best way to do it. It is however the best way to waste money....
Also I wouldn't give "All Pro" a dime of my money....
Do some research, do the work yourself...... this way it gets done right and doesn't cost you more than you paid for the truck.
here is a bunch of pics you can look at for refference.
He, Nate, decided to use a Toyota 8" axle from an '85 Toyota. He swapped the tubes and rotated the Diff.
He also fabbed up his own High steer crossover.
Stage 1 (http://www.boydbrothersservice.com/SAS/sasstage1/)
almost done (http://www.boydbrothersservice.com/SAS/JAN1203/)
81toy3614.50
02-20-2003, 02:53 PM
I have a 81 toyota for parts and am looking at taking the front axle and puting it under a 86 due to emmissions laws I can't put the fuelie motor and computer in the 81. I can't get the link to the pictures to work. I'm assuming you just measure the distance between t-case and axle yolks on the 81 and place the axle under the 86 and drill holes for spring shackles and reiforce the frame where the holes are. i think the frames are the same otherwise:confused:
§©RÉWßã£
02-20-2003, 05:56 PM
since you have both trucks there, just take the measurements from the 81, and mimic that setup on the other truck.
I also suggest switching to a crossover steering setup.
you will need to weld new spring hangers up front and shackle hangers in the rear of the front springs.
81toy3614.50
02-21-2003, 02:26 PM
A friend of mine suggested taking the cab off of both trucks and swapping the engines, trannys, t-cases and placing the 86 cab on the 81 frame because he said the frame on the 81 is tougher and shorter. the 81 is a standard cab long bed and the 86 is extended cab long bed I think having the shorter wheelbase is a good idea.
AWSUMDC
01-28-2006, 07:02 PM
http://img.villagephotos.com/p/2005-10/1096673/earlytacobumper1.JPG
AWSUMDC
01-28-2006, 07:04 PM
http://img.villagephotos.com/p/2005-10/1096673/05bumper3.JPG
AWSUMDC
01-28-2006, 07:06 PM
http://img.villagephotos.com/p/2005-10/1096673/05bumper2.JPG
AWSUMDC
01-28-2006, 07:08 PM
http://img.villagephotos.com/p/2005-10/1096673/my052.JPG
Google
Web AF
