Runs HORRIBLE HELP!!!
Google
Web AF
pontiacs98
08-04-2006, 02:44 PM
I recently put a 3.1L 3100 Engine from a 1997 Lumina into a 1997 GRand AM GT. It starts kinda rough. WHen it is started it will not idle. when its at about 100 R's it sounds good but it then gets a strong gas smell. I had to take the fuel rail, and injectors out of the Grand AM motor and out them on the Lumina Engine. Is that Bad?? It almost seems like it has too much fuel running to it. Im also wondering if the plug wires are wrong bc i hooked them up the way they were on the grand am. can anyone give me info on which wires go on what plugs from left to right on the front and back?? Also any info PLease HELP ME Thanks Tom
richtazz
08-04-2006, 03:19 PM
The firing orders are the same, so as long as you did it right for the Grand Am, it would be the same on the Lumina motor. The engines appear to be identical, including the sensors (MAF, oxygen, etc..) so there must be a problem with the new engine if you have the firing order correct. Did you re-use old plugs, wires, etc.., or did you put new tune-up parts in when you did the swap? It's entirely possible that one or more injectors are bad, as they are a fairly common issue on these engines.
pontiacs98
08-04-2006, 06:19 PM
Yes it is runing better now that i have started it and let it run a little, but the check engine light is flashing and it has a miss making me think i have a plug wire in the wrong spot......Can anyone tell me which plug wires go to which plugs from left to right on the front towards the bumber and back towards the fire wall from left to right please...Thank you for your help so far.
Google
Web AF
