1977 Corvette Horn not working?sharkattack 08-03-2006, 07:10 PM My horn is not working,, after replacing the relay switch, the horn still does'nt work, I can not find a fuse or a fuse link for it,, When I hit the horn button it clicks which I would think means it is getting the electric. Thanks ,, 96_9c1 08-04-2006, 11:13 AM Is the horn self-grounded? If you want, pull the horn and clean both surfaces with a wire brush, then check the connection and then reattach the horn securely :) knuckle ears 08-04-2006, 06:17 PM Is the horn self-grounded? If you want, pull the horn and clean both surfaces with a wire brush, then check the connection and then reattach the horn securely :) I've had the same problem with other vehicles. If all the grounds and power wires are clean and connected and If you can hear it click at the horn then it is the horn itself. Replace it. If you pull the horn for connection cleaning also connect it to a battery or charger, it will work if it is good. sharkattack 08-05-2006, 08:54 AM When I check it directly to the battery do I just go to the positive or both positive and negetive to the horn? Thanks knuckle ears 08-05-2006, 12:59 PM Some use only one connection only which is positive. The bolt that attaches the horn to the chassis is negative. If this is the case then attach a battery lead wire from positve to the connection and another lead from the negative battery to the bolt hole. If it has two connection points, then one is positive and the other is negative. Attach a battery lead wire from positive to any connection and another from negative to the other terminal. Leads may have to be reversed if the horn doesn't work. If horn dosen't work then replace the horn. Vettehead 09-15-2007, 06:18 PM I know this is really going to sound like a dumb question, but where is the horn on my '81 Vette? My horn recently quit working, and I haven't gotten a chance to get under the car yet. I've looked under the hood but could not find it. Thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
