I'm missing a bushing on front stablizer barwnt2rd 07-31-2006, 10:59 PM Hi Everybody! Made a lot of progress on the Neon yesterday. Got the wheels completely back together, installed the rear engine mount, some random bolts and sort of installed the front stabilizer bar When I was taking the car apart to get at the clutch, I lost one of the bushings from the stabilizer bar connection. I'm pretty sure it rolled down the street and disappeared because I couldn't find it anywhere. I took one bushing (there are four on each side of the car) from the other side of the car so now both sides are even, but a little loose. I'm sure this negates the whole point of having a stabilizer bar. Am I right? I'm sure I have to spend an arm and a leg for a new set of bushings for the bar. Does anyone have any suggestions or am I stuck going to the dealer for parts (again)? Will having a loose stabilizer bar have a negative effect on the alignment of the car? das2123 08-01-2006, 12:08 AM Go to the dealer or junkyard for the bushings. yale329 09-20-2006, 10:27 PM No, it will not effect your front end alighn, but for fifteen bucks or so the bolt and bushings come in a set. Just a dad, Good luck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
