trans fluid change
Google
Web AF
GAT
07-28-2006, 11:44 AM
Is it a pretty easy task to change my own tranny fluid? Truck has 103000 miles and has not been touched.
Ape0r
07-28-2006, 12:22 PM
Its a real PITA. I worked at a Chevy dealer last summer and man, this was my least favorite thing to do. Drain plugs are impossible to remove, and you get a bath when you take the pan down.
If you don't mind a bath, go for it. Personally... I'm going to pay someone else to do it when the time comes =).
At 103k there may not be any point though.. I've heard that if you don't do it by 50k, to leave it alone. I'm sure others have different opinions.
The process is simple enough:
1. Bend shift linkage out of the way (some remove it, but its easier just to bend it out of the way)
2. Remove pan (~15-20 bolts)
3. Change filter (easy, pulls right off)
4. Clean off old gasket
5. Install new gasket, reinstall pan, dump in 4-5 quarts
6. Hope your trans doesn't 'splode instantly =)
GAT
07-28-2006, 12:26 PM
Gee you make it sound so inviting ha. I will talk to my mechanic and let him do it. Thank for the reply
firedawg81
07-28-2006, 03:06 PM
Ah it isnt that bad. And your looking at $60 dollars or so and an hour or two of your time compared to $150-300
GAT
07-28-2006, 03:15 PM
Wow is this your rig??? Nice darn truck! I thought mine looked good, yours is right on, not over done...Only thing I will add to mine is running lights on the cap.
MT-2500
07-28-2006, 04:53 PM
Some harder than others.
I do not think yours is real hard.
But you have to watch and not knock off the electrical solenoids plug on wires.
The back of the pan is a tight fit against crossmember on some.
Some will need the transmission raised up or crossmember slid back a little.
Reuse the reusable hard rubber molded pan gasket if it has it.
It should have been done sooner but do it now.
If you do not do it your transmission will fail later.
People that keep them serviced have a lot less trqansmission trouble.
MT
firedawg81
07-28-2006, 04:54 PM
Hey thanks bud, I really love my truck..I dont love the mpg with the gas prices now days though but i can deal with it. Im about to drop a heavier duty Rear Dif really soon. Those bigger tires are a little rough for the small stock dif.
MT-2500
07-28-2006, 04:58 PM
Good grief.
Why bend linkage?
Why throw away a 25$ good re usable oil pan gasket?
We are not working on a old junker here.:grinyes: :lol:
This is a late model GM be nice to it and let it have a new filter and some fresh fluid and it will be your buddie for life. :grinyes: :rofl: :lol:
MT
Ape0r
07-28-2006, 05:25 PM
Good grief.
Why bend linkage?
MT
1. Faster to bend it than to mess around with the torx bolts holding it on.
2. Gasket is definitely NOT reusable on a 4L60-E - if it were, then why would it be included with the filter?
/Funny how junky old Lumina's have reusable gaskets, but the new trucks don't.
//You definitely don't have to use a wire wheel or grinder to get off reusable gaskets
///Slashy
MT-2500
07-28-2006, 06:07 PM
///Slashy
Ther is no need to fool with the shift linkage.
Most OEM 4L60E transmissions have the resuable molded hard rubber gasket un less some dummie has throwed it away the last time it was serviced.
The cheap aftermarket kits throw a cheap pan gasket in with there oil filter kit.
But do not even use it unless you have to. They are crap.
Go to the dealer and get the OEM good stuff.
MT
Ape0r
07-28-2006, 06:22 PM
MT
I worked at a dealer last summer. I am speaking of the OEM stuff. AC Delco. Filter and gasket come shrink wrapped against a piece of cardboard. Did trans fluid changes on three or four NBS trucks/SUVs.. didn't see a single reusable gasket. One only had 35k on it. Its possible they changed for '05.. but I doubt it..? All of the cars I worked on definitely did have the reusable gasket.. man that was NICE!! Such a PITA to shave off the old gasket...
Next thing that you're doing to tell me is that the diff gasket I spent 2 hrs grinding off with a dremel two months ago was reusable! :grinno: Sure do miss the air driven wire wheel we had at that dealer when I get to doing this crap..
..and if you still don't believe me, see
http://gm-trucks.com/home/content/view/229/25/
and
http://img154.imageshack.us/img154/3082/filterqm5.jpg
and
http://disabled-parking.com/images/r/retarded.jpg
/Really wish I had something better to do
//Gave the gf my cold.. now she doesn't want to go out tonight
///Slashy
MT-2500
07-28-2006, 06:30 PM
If they do not have one git one and put one on there and it will be there for the next time.
Mt
guumbah
07-30-2006, 06:05 PM
I've heard the same thing. My question is, do you do it around 50K even if the fluid looks and smells perfect?
Blue Bowtie
07-30-2006, 06:42 PM
The drain plugs are not that bad if you plan ahead and apply some penetrating oil to the plug and area a few days before you plan to drain it. It's certainly worth working on a bit to avoid the mess of dropping an edge of the pan without having a very large drain pan.
pshadwick
07-31-2006, 11:42 AM
MT
I tried to do mine a couple of weeks ago. I gave up and reinstalled the pan as I couldnt get it past the shift linkage, couldnt get to the torx bolts to remove the linkage, and was unsure about bending it.
So is it safe to bend the linkage? No concern about cracking the case?
...Paul
MT-2500
07-31-2006, 12:28 PM
...Paul
No it is not safe to bend the linkage.
Anytime you bend somthing like that it may crack or break.
If all else fails do so at your own risk.
MT
GAT
07-31-2006, 02:36 PM
I don't thik I am going to mess with it. Thank you for the help.
Google
Web AF
