door adjustments
Google
Web AF
lifeiscars
08-14-2002, 01:26 PM
i have a 96 jimmy, which is the same thing as a blazer. my door, it does not pop open when you pull the handle from the outside. It just kinda sits there and then you have to push it open....this is only on the drivers door. all the other doors i beleive pop open. is it just me or my imagination or is there some way to adjust it.
mitchy_v
10-06-2002, 12:50 AM
sounds like you need new pins and bushings
Trail Blazin 96
09-03-2004, 07:24 PM
the pins go out you need to get some new ones!
MGoBlue102
09-03-2004, 07:36 PM
yep, common problem, pin and bushings can be found in the little red boxes in the help section of any auto store. The bad thing is the pesky little spring that sits in front of the pin, you can just pull it out but getting it back in is a beotch unless you got that handy little door spring compressor tool. It costs about 30 bucks online, couldnt find that tool anywhere local.
BlazerLT
09-04-2004, 07:43 PM
No being rude, but when ever does a door "pop" open?
Trail Blazin 96
09-05-2004, 04:34 PM
that is a good question BlazerLT and the only time they do is if you have remote entry, which is a nifty little thing if you have someone trying to break in to your car! unless the Bastards break your window out!
BlazerLT
09-05-2004, 04:39 PM
True, I have heard people having these types of setups but in this case, I think he is stock right?
Google
Web AF
