how to wire 99+ mirrors to 97..zachzchw 07-25-2006, 12:19 AM I searched, and didnt come across a step by step on this. I bought new mirrors to replace the ones on my 1997....the ones I bought are heated. How do I hook these up to my defrost switch, so they will heat up? The car does not have the heated mirrors now, so I know I will need to tap into the defrost wire. zachzchw 07-26-2006, 09:05 PM I know quite a few of you have done this... billibong 07-27-2006, 09:04 AM I just pulled this from another post. I am quoting the original author, which was me, "Pick up a haynes manual and it has the wiring diagram in it for the outside power mirrors. Right outside mirror: Lt Blue and Lt Grn/Blk - ECB Yellow/Blk - Motor Up/Down Switch White/Blk - Motor Left/Right Switch Left OUtside Mirror: Lt Blue/Lt Grn - ECB Yellow - - Motor Up/Down Switch White - Motor Left/Right Switch ECB connections go to Mirror position switch inside truck. From the switch in the truck Like to like on all connections with the exception of the ECb wires that connect to the Light blue from the interior switch. Black to Ground Orange to Fuse block courtesy fuse 2 (hot at all times). Hope this helps." This was in an earlier post where someone hooked up mirrors in their truck. I believe, but am not positive, that the ECB wires supply power to the heating elements. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
