help
Google
Web AF
serbring
07-23-2006, 09:02 PM
where in the connection for the air condition on a Volvo 240 DL I cant find them and the system need recharged
serbring
08-01-2006, 05:22 PM
are you referring to the pressure valve? it should be located under the hood behind the headlamp.
AC system (http://www.innerauto.com/Automotive_Systems/A~c_Heat_System/) faults usually cause cars to be stranded so you may also seek the help of a qualified Volvo technician if you feel that your car had a serious problem.
i need to recharge the system and i cant fine where the conection are
chester08
08-04-2006, 08:28 PM
I recommend that you refer to the service manual of your car. It can provide you also with additional info regarding your AC system. It should help you with the specifics including the wirings.
Google
Web AF
