96ztt Turbo hardware installation??
JCCR
07-23-2006, 02:57 PM
We are in the process of installing the new turbos ( GT525 ) from Z1MOTORSPORTS but i kind of forgot how the oil feed lines and water by-pass hoses go:banghead: those any body have pics of turbos and hardware installation??? any help would be apreciated. the turbos are already mounted i just need to be 100% sure that i got all the hoses in the right place.
thanks
jc
thanks
jc
Broke_as_****
07-23-2006, 04:01 PM
From the pictures of the kit it uses all stock oil and coolant lines. Check your handy factory service manual for routing of those.
If you've done the throttle body coolant tube by pass then the proceedure is basically the same except for two of the tubes:
http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=880107
The passenger side:
http://www.streetneeds.com/uploads/twinturbonet/2015.JPG
The drivers side
http://www.streetneeds.com/uploads/twinturbonet/2013.jpg
On the drivers side as you can see you have to run about an extra foot or so to loop it around to the front of the coolant inlet. I think this is stupid. So I took my pipe bending tool and did this:
http://img160.imageshack.us/img160/5818/2013altwv7.jpg
Red is the normal bypass route, green is what I did. I guess I forgot to take a picture of it but you can kind of see it here:
http://img73.imageshack.us/img73/5927/picture039altgj4.jpg
The passenger side:
The drivers side
JCCR
07-23-2006, 08:59 PM
thanks broke, this is exactly what i need it
Broke_as_****
07-23-2006, 09:17 PM
Thats what she said. :wink:
