Compression?
sweetcarz.com
08-13-2002, 06:37 PM
My compression starting with cylinder one is 140,95,95, and 138. What is wrong with my car? Someone told me there is a crack in the cylinder block between cylinders 2 and 3. But I dunno, some other cracka told me I have a leaking cylinder head gasket between 2 and 3.
sparq
08-13-2002, 06:39 PM
your compression is low cause you dont have enough blinker fluid - thats what the guy at midas told me. That and he said I had a rice cooker? I told him I dont like rice it looks like little white ants :o
sweetcarz.com
08-13-2002, 06:55 PM
so I shouldn't worry about my head gasket. :confused:
GSteg
08-13-2002, 11:29 PM
piston rings fried possibly?:cool:
mellowboy
08-14-2002, 11:01 AM
Yeh it could be the piston rings or the head gasket.
white97ex
08-15-2002, 11:42 AM
im not a honda nut. but with an open deck block the seeves on the 2 and 3 cylinders would have to both be cracked. and for it to be the rings the rings on both pistons would have to be cracked. i would guess it is the head gasket but i am no expert. just my assumption. take it to a shop and have a leak down test performed on it that will tell you exactly where the problem is
