Wheel bearing or CV joint or ???
Google
Web AF
DRGREENTHUMB1001
07-22-2006, 10:36 PM
I have a squealing sound coming from my front driver side wheel. It only squeals when I am backing up. At low speeds I hear what I can only describe as a "clicking" noise, like ball cards on a bike tire, something like that. My pads and rotors are all new are close to it. So its definitely not that. It also seems that where the front axle shaft goes into the "whatever" the boot leaks that special grease right around where the stainless steel band is that keeps the boot on, but both sides are leaking it while only the driver side is squealing and clicking.
Thanks for any and all help
MT-2500
07-22-2006, 11:41 PM
You answered your own question.
Clicking sound points to axel shaft.
MT
jhong1226
07-23-2006, 12:27 AM
If you are going to change the cv axles, you might as well change the bearing. it cost about 10 to 15 dollars anyway, so might as well do it then.
BlazinMlew
07-23-2006, 02:27 AM
What bearing only costs $15??? Not a wheel bearing for sure. Those are at least $60 out of the box and that is with an associate price for me.
jhong1226
07-23-2006, 08:24 PM
oh, the price i was lloking at was for a 2wd. 4wd actually cost more coz it comes with the hub.
BlazerLT
07-24-2006, 12:25 AM
Did you install grease on the back of the brake pads?
Also did you bend the pad ears tight in the caliper?
BlazinMlew
07-24-2006, 12:26 AM
Ok Good cause I thought I was getting screwed. That would have sucked.
Google
Web AF
