Wiring an Amp in my '00 SilveradoOGG 07-22-2006, 05:15 PM I got a couple of questions for you audio guys. Can I hook the power wire for an amp to the little red box marked "battery" by the alternator or will this create noise? Also, can I ground the amp to the mounting bolt for the back seat? kenwood guy 07-22-2006, 06:59 PM I got a couple of questions for you audio guys. Can I hook the power wire for an amp to the little red box marked "battery" by the alternator or will this create noise? Also, can I ground the amp to the mounting bolt for the back seat? yes you can thats what I did and I get zero noise OGG 07-23-2006, 07:16 AM Thanks. I figured as much but I thought I'd ask to be sure. I hate doing thngs twice. FiTxAg04 07-23-2006, 12:02 PM yes you can thats what I did and I get zero noise I second that. Sounds like a good connection to me. sportin83 07-25-2006, 12:04 AM ya you can hook there or straight to the battery. the only way you will get noise is from a bad ground or having cheap rca's or having rca's to close to power wire throughout the truck. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
