torque specs?jjubeck619 07-22-2006, 10:33 AM I'm looking for the torque specs for the heads on a 99 gt. Thanks for the help BNaylor 07-22-2006, 11:07 AM Are you using new TTY head bolts? There is a specific procedure. Take note below. Torque to 37 ft-lbs on the first pass, then 120 degrees second pass. And the bolts should be torqued in a certain pattern. jjubeck619 07-22-2006, 11:20 AM Thank you man I appreciate the help vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
