Question about larger motors and swapping
Google
Web AF
Young Chuck D
07-20-2006, 03:43 PM
i am hearing that a Lumina engine would fit in my 89. its a 3.1 MPFI i think. i also hear that its an aluminum block and extra sensitive to heat. now if i were to make that swap i'd probably rig my fan to be on always or by a switch controlled by me. also would check my cooling system weekly. but i was wondering if theres a 3.1 chevy block i could put in thats not aluminum? or should i even want that? is 550 a good price? is my transmission gonna co-operate with it?
Young Chuck D
07-20-2006, 04:59 PM
i don't know why i thought j-body heads would know about a lumina engine... i'll repost this in the nonspec..
Young Chuck D
07-21-2006, 02:06 PM
seems like all people can be good for is help painting your interior or what kind of pipes to use or how to remove a fuckin dashboard... you people and your toy cars..
jakegday
07-21-2006, 06:40 PM
you should know that by now..... and we can also tell you which exhaust setup to get
Young Chuck D
07-21-2006, 10:06 PM
thats what i meant by pipes.
but damn, at least somebody point me in the right direction...
MrR0b0t0
07-21-2006, 10:42 PM
I really dont think many people here have attempted engine swaps, especially with an '89.
Young Chuck D
07-22-2006, 01:07 AM
wasn't there a cavalier that came with a 3.1?
i know i've seen it before...
Crazzzyj
07-22-2006, 01:43 AM
There are several long and short 3.1 blocks that aren't aluminum. The closest one I found to the year of your car ran for about $450. Being its GM, most parts should be interchangeable. Now, if there was a 3.1 in a Cavalier, I would have to say it must've been a Z24 in the years 87 - 89. It does sound familiar, and I strongly think some 88's had one but not for certain.
~Crazzzyj
Young Chuck D
07-22-2006, 06:06 AM
~Crazzzyj
FOUND IT
1990 Cavalier Z24 V6 3.1 FI
*on a mission*
Young Chuck D
07-22-2006, 06:29 AM
my God! SUCCESS!
Thank You Lord!
http://i5.tinypic.com/20q01h2.jpg
Young Chuck D
07-22-2006, 06:43 AM
wow what a sig this would be:
http://i5.tinypic.com/20q04sk.jpg
iron1951
07-22-2006, 10:43 AM
Young Chuck D, please let me(us) know how the swap goes. I have an 87 with a NFG 2.8, sounds like a spun bearing and was wondering about putting in a 3.1. Besides the tranny, I was also worried about the computer hookup, would I have to rewire or could it be just plug and play? But a 3.1 turbo, wow. Please keep posting on how it goes.
OverAllComa
07-22-2006, 12:24 PM
The 3.1 Turbo from a TGP has been done before, but you'll run into trouble. The motor doesn't want to fit all the extra hardware into the engine bay of a j-body, but it can squeeze into a grand prix just fine.
3.1 Iron block, aluminum head was a 1990-94 thing. Before that was the 2.8 w/ iron head.
As for your lumina engine, it should fit just fit with the proper mounts, though it would be easier to just steal a Z24 motor and swap that. You'll know all the hardware will be matching up that way. And the biggest reason its kinda hard to give you a straight answer on the lumina was b/c I didn't see a year mentioned. Those things could have a 3.1 or a 3100, and while very VERY much the same motors, there are some differences.
If you still have various questions, consider doing a search on www.j-body.org in the 2nd gen forum. Most of this has already been covered.
Young Chuck D
07-22-2006, 01:30 PM
check back in a month and a half, i sorta got fired and re-hired and don't start working until early august and then will need to save up 2 paychecks and i'll get it going.
Young Chuck D
07-22-2006, 01:32 PM
i thought 3100 and 3.1 were exactly the same? 3100 cubic centimeters and 3.1 liters are the same amounts in different measures
Lances133
07-22-2006, 03:18 PM
If you don't like it, go to Jbody.org. You should know by now this forum isn't full of professionals and geniuses. And I guarentee you, being a smartass won't better your odds.
noshun
07-22-2006, 08:17 PM
3100 is a newer version of the 3.1. all of the 3.1 ohvs are the same. You need to buy older then 95 so it's an OBD 1 motor.
The 3.1 was fitted to pretty much every gm car j-body to w-body.
The 3.1 I believe only make more torque than the 2.8 but no more power.
you're probably best off with a 3.1 fomr a cav so that the pcm will work with your guage cluster. Or you might have to swap that also!
Young Chuck D
07-22-2006, 08:44 PM
so you're saying a turbo designed by mclaren isn't much better than a regular 3.1 designed by general motors?
i mean really, they're the same price and as long as fitting it won't be A HUGE hassle, i would rather say that i have a turbo. but if you do know, tell me how much the turbo changes.
Young Chuck D
07-22-2006, 08:45 PM
actually i just signed up over there, and the first thread i opened i saw KustmAce in it lol...
lances i'm sure you're not angry.. when i said toy cars i meant that most of the members here have newer j's than me...
Google
Web AF
