1996 Lumina DIFFERENTIAL PRESSURE SENSOR
Google
Web AF
84'MC350
07-16-2006, 09:54 PM
Where is the DIFFERENTIAL PRESSURE SENSOR located on the 96 Luminas?? I got a code P0401 and I know its not the egr valve so im thinking its maybe not getting enough vacuum???
richtazz
07-17-2006, 12:43 PM
what engine do you have?
84'MC350
07-17-2006, 11:47 PM
the 3.1L
thanks
Blue Bowtie
07-18-2006, 12:10 PM
AFAIK, the '96 used a digital EGR, and the PCM relied upon changes in the MAP to detect EGR effectiveness and flow. Fords used a DP sensor, and they commonly fail intermittently. Your Lumina does not.
If the PCM is storing a 401, you might want to check the continutity of the three solenoid coils within the EGR, and check the EGR passages and valve pintle areas for carbon, coke, and contamination. When you get the EGR valve removed, also check the base ghasket condition.
richtazz
07-18-2006, 01:00 PM
I agree with Blue Bowtie, your car has a digital EGR, so there is no DP sensor or EGR position sensor. The tube from the exhaust manifold up to the intake may be clogged or pinched. Check the vacuum line to the MAP sensor for cracks. A bad vacuum signal to the MAP will trip a code p0401.
Blue Bowtie
07-18-2006, 01:55 PM
I agree with Blue Bowtie...
Whoo! That can be dangerous. I don't even agree with me most of the time. It takes a long time to convince the voices in my head that they can all just get along.... :D
richtazz
07-18-2006, 03:27 PM
Sounds like we have a lot in common Blue.
Google
Web AF
