brake troublehime_99 07-16-2006, 12:35 AM i have a 1996 s10 blazer i put a new master cyclinder on and brakes bleed the system 5 time and yes the master cylinder to but still have a soft brake pedal check the brake booster it was okhave no brake light on someone told me i could have air in the abs system if this is true how do i bleed it i have 2 bleeders on itdo i bleed them like the brakes or what?:banghead: :banghead: jd-autotech 07-16-2006, 01:00 AM yes just like bleeders at the wheels but there are what looks like pins that stick out of the unit they must be compressed and yes it takes a special tool jd-autotech 07-16-2006, 01:01 AM the tool clamps on the pins BlazerLT 07-17-2006, 02:56 AM i have a 1996 s10 blazer i put a new master cyclinder on and brakes bleed the system 5 time and yes the master cylinder to but still have a soft brake pedal check the brake booster it was okhave no brake light on someone told me i could have air in the abs system if this is true how do i bleed it i have 2 bleeders on itdo i bleed them like the brakes or what?:banghead: :banghead: Your rear brakes need to be adjusted. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
