'95 #3 cylynder misfirerlbck38 07-14-2006, 09:09 AM '95 Blazer LT engine code w Engine was replaced with a rebuilt in March '06 Currently the #3 cylynder is misfiring. Is this normal after approx. 5k miles? Is there a trick to get around the steering column to change the #3 (or 4, I forget 1,3,5 on left or right) plug? ZL1power69 07-14-2006, 11:26 AM i would check that plug and the plug wires. heres the link for how to change the #3 plug; http://www.automotiveforums.com/vbulletin/showthread.php?t=503231. i would also look inside the upper intake to see if the nut kit (fuel inlet and return lines) is leaking, since its on the same side as the #3 plug. is ur check engine light on? if so, scan it and post the codes. BlazerLT 07-14-2006, 12:04 PM I think the cpi and nut kit are leaking use a search to get more informed about the two or check out the FAQ at the top of the blazer forum. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
