Low coolant light and car overheated at idleXalis 07-14-2006, 08:40 AM I was at the drive in sitting at idle listening to the movie on my stereo. I had to sit at idle because i have 2 amps hooked up to my system drawing 900 rms. All of a sudden i noticed steam coming from under the hood and shut my car off. The temp gauge was at max and the car was hot. I popped the hood and let it cool down, then added water to the coolant reservour. I noticed some coolant leaked out near the reservour down on the body and frame. There was no coolant by the engine or flung around like when a water pump is leakin. I was wondering if you guys have any idea what happened or what I should look for to be broken. After i added the water and my car cooled down, I drove home without any problem. Also the low coolant light comes on everytime I shift at high rpms (its an automatic) but the coolant is never very low at all, maybe 6 oz low. jakegday 07-14-2006, 09:15 AM my low coolant light comes on EVERY time i put im foot in the accelerator, or make a sharp turn, if it was your water pump you would not have driven home without any problem, are you sure your radiator fan is kicking on?? Cavalier2000 07-14-2006, 05:11 PM or thermy? take that water out as well and put in antifreeze Xalis 07-14-2006, 05:33 PM not sure about the fan, probably wasnt but i dunno Xalis 07-25-2006, 05:58 PM fan relay, all fluids are changed and fixed dynastyperformance 08-04-2006, 12:04 AM the coolant light is normal , mine stays on for a bit everytime i take off or let the engine wind above 4 grand 99chevycav 08-04-2006, 11:28 PM i had the same problem with the low coolant light coming on when accerating and sharp turns.added some coolant and light hasn't been on since. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
