94 with messed up turnsignals
blazin97
07-13-2006, 04:50 PM
I have a 94 Beretta thats turnsignals are messed up. They work some times but other times they just light up and dont flash. Replaced the hazard flasher and it didnt help.
Thanks,
Blazin97
Thanks,
Blazin97
richtazz
07-13-2006, 08:56 PM
double check the bulbs when it isn't flashing. Turn-signal bulbs can work intermittently. The filiment can break near the end, and when you hit a bump, it will lose contact and not work. Then you it another bump, and it will hook itself around the post it is originally soldered to and work again. There are two flashers in your car, one in the fuse box for the flashers, and a second mounted near/clipped to the steering column, or between the column and the radio. The one in my 91 cavalier was there, and I had to remove the radio to gain access to it.
blazin97
07-16-2006, 01:25 AM
Thanks I replaced the bulbs and now they work fine.
