Hello, Everybody. Truck Shakes When I apply the brakes at 65-75mph.GirlBear 07-11-2006, 11:34 PM Figured I'd start this one off with a pleasant Greeting. My lovely Blazer Shakes when I apply the brakes at 65-75mph. Sort of a Wub,Wub,Wub,Wub,Wub,Wub sound. Tires aren't new Had'em rotated and balanced a few months ago. new ball joints. new brakes/pads. ??Clueless?? kb3jhp 07-12-2006, 02:37 AM did you get new roters or the old ones turned if not its most likely a warpt roter BlazinMlew 07-12-2006, 08:14 AM did you get new roters or the old ones turned if not its most likely a warpt roter Thats what I would think as well. Even if you did get new ones just could be a bad one (improper storage at the parts store or somewhere can cause it) :banghead: , its happened to me, I replaced them again and the shake was gone. BlazerBoyLT98 07-12-2006, 10:44 AM Warped front rotors! prototype80 07-12-2006, 02:26 PM definately the rotors, i had that problem one to many times. cost will depend on if you doit yourself or if you have someone else do it for ya. BlazerLT 07-12-2006, 04:15 PM Warped rotors. muzzy1maniac 07-12-2006, 05:08 PM Will warped rear rotors cause shake in the wheel? BlazerLT 07-12-2006, 06:28 PM For sure it will. blazes9395 07-12-2006, 07:11 PM Will warped rear rotors cause shake in the wheel? What do you mean...steering wheel? muzzy1maniac 07-12-2006, 09:39 PM What do you mean...steering wheel? Yup GirlBear 07-13-2006, 10:45 PM thanx everybody. I was thinkin rotor 2. but with the blazer ya never know. thnx again. DINO55 07-14-2006, 12:39 AM Hi Girlbear, When you replace those rotors, Make sure you wire wheel and GREASE the heck out of the Caliper Slide Pins. Good luck and Let us know how it goes... BlazerLT 07-14-2006, 01:14 PM Also wirewheel and sand the rotor mating surface with the hub. Get all the grease off of there and make sure it is smooth. Chances are that might be causing the wobble with you existing ones or they could be just warped. But warping does come from overheating in most cases so your caliper could be sticking. As dino said, get those pins greased up. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
