Crown Victoria Gas Gauge Not working
5.56x45mm
07-11-2006, 08:19 PM
When I bought the 99 Crown Vic the Gas gauge was stuck above full and would not move. The check engine light came on and I had my friend run the code, it said something about the sending unit. I changed the fuel pump and filter. There was a wire, I believe a yellow one, that was disconnected, I reconnected it and now the gauge stays below empty, even when the tank is full. Any ideas?
BMFer1
07-12-2006, 07:50 PM
What did you connect the yellow wire to? It should connect the the sending unit, or to a short yellow wire that connects to the sending unit.
