RHD '89 2vz-fe camry speedo joys7polly7777 07-11-2006, 01:13 PM Hi, A couple of quick questions before I end up 'cracking the dash' open again on the aforementioned car. Problem: - Speedo is usually rock-steady; though recently has intermittantly started jumping around significantly accompanied occasionally (at the same time) by an audible clicking from somewhere behind the speedo. Guess as to problem: - Top section of speedo cable worn/wearing More problems: - As car is a RHD I am struggling to get a new replacement part for a reasonable price here in Australia. Questions for you: - If I take the gauges out of the dash and remove the speedo cable; is the cable the sort that I can get into to lubricate it? If so, what is the best thing to lubricate it with (eg: silicon grease spray?). I don't fancy dismantling the car twice if I cannot get to the part to do this! - Does the SV21 i4 engine use the same speedo cable? I can find loads of these in the wreckers; but none of the V6 variants. Thanks in advance for your input Matt vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
