Multi-Port Injector Question and a few othersJovian9 07-07-2006, 04:46 PM My check engine light came on yesterday. The code read P0305 (misfire in cylinder 5). It turns out that the Multi-Port injector for cylinder 5 needs replaced. Am I safe to drive with this for a few days until I have time to get it fixed? Also, I have a rattle sound coming from somewhere and I can't tell exactly where it is at. It sounds like the front but also seems like it could be exhaust related. This time last year Isuzu removed a heat-shield in the front which they stated was causing a sound that was exactly like this. It sounds like a thin sheet of metal or something Anyone have experience with this? When I am about to stop and am pulling into a parking spot at my apartment I hear a low-popping sound. I only hear it when I am stopping, but that could just be b/c it is so quiet and the car noise is not drowning it out. It almost sounds like there is something that may need tightened in the front. Any ideas? Thanks! rodeo02 07-07-2006, 06:26 PM What year? What engine? Did you just have the spark plugs changed? I've never heard of a fuel injector needing to be replaced if this is a 3.2L. 2000+ dont run well with certain brands of sparkplug & will throw a misfire code. Joel Jovian9 07-07-2006, 06:59 PM What year? What engine? Did you just have the spark plugs changed? I've never heard of a fuel injector needing to be replaced if this is a 3.2L. 2000+ dont run well with certain brands of sparkplug & will throw a misfire code. Joel Yeah, I guess that info would have been valuable to include in the original post. I have a '99 V6 4WD Rodeo. The spark plugs were changed in August of 2004 and no issues until now. Ramblin Fever 07-07-2006, 07:55 PM Check the tightness of your spark plugs - make sure one didn't wiggle loose, i.e. misfire code and rattling sound. We have an '85 Toyota 22RE p/up - granted a whole different vehicle entirely, however just before last winter truck begin running terribly and the front of the truck/engine begin sounding like a bag of M&M's. Turned out one of the spark plugs had wiggled loose. Probably a shot in the dark, but you do have a mis-fire code, which I would think is probably more spark-plug related. And, the plugs could just need changed after 2yrs. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
