2001 Rodeo Check Engine Light Stays On
Google
Web AF
angela5503
07-07-2006, 08:31 AM
01 Rodeo Check Engine Light Came On Steady But It Seems To Be Running Fine. Anyone Have An Idea And Should It Be Ok To Drive Untill I Can Get It Checked Out?
drdrew33
07-07-2006, 08:37 AM
If its running fine, it will be okay to drive until you can get it checked. A lot of times this is a bad O2 sensor.
Ramblin Fever
07-07-2006, 09:20 AM
Welcome to the club! :banghead:
Mine's been off and on for 6 mnths, changed out all O2's, cleaned EGR 4 times, throttle body twice, runs fine with or without the CEL on - if I wasn't worried about not passing emissions in February I wouldn't even give it a 2nd thought - except I'm tired of the idiot light on the dash.
The CEL steady light is ok to drive with, it's when it's flashing that it's not good to drive. And the CEL doesn't always mean a bad O2, especially on the newer Rodeo's - it's usually a clogged EGR valve.
Go to Autozone, they'll read your codes for free, post them back here so we can help.
Canucklehead
07-07-2006, 11:48 AM
The CEL steady light is ok to drive with, it's when it's flashing that it's not good to drive. And the CEL doesn't always mean a bad O2, especially on the newer Rodeo's - it's usually a clogged EGR valve.... or loose gas cap. :)
rodeo02
07-07-2006, 06:27 PM
Could be one of several hundreds of OBDII codes. Autozone will read and tell you the code for free. Try there.
Joel
Google
Web AF
