egr connectorhcivic 07-06-2006, 11:54 PM :banghead: I have a 87 camaro 305 tpi.Just put new cam in and after puting everything back together I have two connectors that i do not know where they plug in. The first is the egr valve cn it comes from under the plenum. The second is a connector behind the rear valve cover its a two pin cn that seems to come out of the wiring harness. I put a new throttle body on also and the car will stall out when maf sensor is plugged in. Not sure if cn not being plugged in is causing car to stall. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
