key stuck in ignition
Google
Web AF
skyjack
07-06-2006, 08:39 PM
i have a 1997 astro i have a problem with the key stuck in ignition and it wont go back to accessorie has anybody had this problem or could it be the ignition switch taking a crap and if so is it a hard job replacing it and what is involved and i have to wiggle the key to get it to shift from park and now it will turn over but not fire thx for any suggestions
89&94
07-13-2006, 09:46 PM
My first question would be is this the ORIGINAL FACTORY key or one that has been made at a hardware store?
We had a spare key made (Always try to use the Factory Key as a master NOT a Copy when making a new key) The spare key that we had made would work, but it would be hard to get to ACCY.when turning it backwards! The Factory Key did not have this problem, thus the key machine or operator did not make a good copy.
I would suggest getting some lock Lub if this is not the case. You may find it will fix your problem.. Replacing the ignition lock requires some special tools.
Good Luck!
Google
Web AF
