a lonely wire.Genopsyde 07-05-2006, 09:23 PM ok, i'm gonna give you guys first crack at this one. Below are 2 pictures of a wire connector that I have no clue where it's supposed to go. It looks as if it goes on a flat blade type connector. The wire is green and it runs with the o2 sensor connector. This is in my 91 RS btw. http://home.comcast.net/~genopsyde91/wire2.jpg http://home.comcast.net/~genopsyde91/wire1.jpg daman 07-06-2006, 08:02 AM Temp gauge.... does the gauge work??? wrightz28 07-06-2006, 11:05 AM :iagree: between cyls 1 & 3 Genopsyde 07-06-2006, 05:41 PM is this on the block or the head? FormulaLT1 07-06-2006, 10:47 PM its in the head that sensor but that pigtail doesn't look like yours. Your pigtail looks like a knock sensor but I am not sure if you have one in that area. I would suggest looking at the wiring diagram for a green wire in that area and then look what is green and not hooked up. 88camaroproject 07-07-2006, 01:54 AM the temp sensor has one cingle green wire. and its on the drivers side head. i thinks its a 11/16 too. dont take it out just plug it in. it uses a blade type connector i think, some have like a nipple thin and the connector slides on sideways. pics are pretty fuzzy so its hard to tell. but check it out. looks like it slides over the nipple thing sideways wrightz28 07-07-2006, 10:50 AM John you're thinking of the fan switch again. :nono: FormulaLT1 07-07-2006, 11:27 AM The fan switches on and off via the reading it gets from a coolant temp sensor. Yes there is more than one but both of them measure the temp of the coolant. wrightz28 07-07-2006, 11:32 AM i was talking aobut the connector types, 3rd gen: CTS-front of engine/intake -2 wire male plug connctor temp sending unit- left side cyls 1&3- 1 wire balde connector fan switch- right side cyls 6 & 8- 1 wire pressed fit (almost exaclty like the knock sensor) FormulaLT1 07-07-2006, 11:34 AM i was talking aobut the connector types, 3rd gen: CTS-front of engine/intake -2 wire male plug connctor temp sending unit- left side cyls 1&3- 1 wire balde connector fan switch- right side cyls 6 & 8- 1 wire pressed fit. Oh, ok. On LT1's the pigtail/sensor is the same on both. So my bad :iceslolan wrightz28 07-07-2006, 11:40 AM That's ok, I was trying to edit in that the fan switch and the knock use the same style connector but was interrupted. :cheers: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
