P0 171beetle1 07-04-2006, 09:03 AM I have a 2001 1.8T with an intermittent check light. The error code P0 171 indicating Bank 1 Too Lean. If reset, the light stays out for 1-2-3 days then comes back on. Car runs degraded when on. I've found info pointing towards MAF sensor. Is this correct? Thanks veedubmechanic 07-09-2006, 07:40 PM could be maf sensor. Check the breather lines under the intake manifold for oil residue. This would indicate leaking hoses. If there ok I would try replacing the maf sensor, but just to know a faulty front o2 sensor also can cause a system too lean code vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
