CEL problems
Google
Web AF
matthew46
06-30-2006, 05:08 PM
I recently have been having a problem with the CEL due to a faulty O2 sensor which I thought I fixed with an aftermarket sensor. However, the CEL came back on and then later after about 125 miles went out again. I was driving on the highway to Oklahoma from NY so this was an extended trip. for the majority of the trip the CEL was off, 5-600 miles or so and then on again for about 125 miles, then off again. What is going on? Going crazy here trying to figure out what's happening.:screwy: The aftermarket sensors are terrible to hook up, I would suggest using OEM fom now on. But there on back order.
Ramblin Fever
06-30-2006, 05:42 PM
Go to Autozone and get your CEL code read - post back what it is.
marcre
06-30-2006, 09:22 PM
what year/model/engine ect...
I used a Bosch with the OEM connector and it worked perfectly. Was only $50 too, so not so bad. Like RF said, go get the code read for free because it may be a different code all together.
marc
boaz2020
07-01-2006, 10:38 AM
Since you were going on a long trip me thinks you got a tank of gas... :grinyes:
...Just for fun check the gas cap, maybe during fuel stops it was loose at one point, after fueling up you corrected the problem, light goes out.
Just an idea.
-Phil
rodeo02
07-01-2006, 03:30 PM
I recently have been having a problem with the CEL due to a faulty O2 sensor which I thought I fixed with an aftermarket sensor. ...
If it was a lean or rich code from one of your upstream O2 sensors, the sensor is not the culpret.
Joel
matthew46
07-03-2006, 06:45 AM
Got the codes read, P0131 and P0137. Same codes as when I first had this problem. Dealer won't touch it since I put in an aftermarket sensor. I was thinking that the EGR valve might be the culprit?
boaz2020
07-03-2006, 11:38 AM
Did you get the O2 w/ the OEM style connector, like marcre suggested? Or did you splice the connector?
If you spliced, check your splice first!
Things to test...In this order.
-Check the harness on the O2 sensors you messed with (ie: check for corrosion and the pins being pushed back in the connectors)
-Try to hand-over-hand the harness wire back a ways, make sure the wires are not damaged (ie: laying against exhaust system somewhere).
-Vacuum hoses (splits/cracks)
-Check PCV for proper installation and condition (it should rattle, if you're brave, blow into the outlet (intake manifold side) and make sure it stops flow)
-Check the Mass Air Flow sensor (ie: no blockage in the screen)
-Check Fuel pressure
-Check Fuel filter (see above)
Good Luck!
-Phil
Google
Web AF
