93 accord only running on #1 and #3 cylinders
rasta1
06-29-2006, 01:47 PM
My 93 accord is only running on the #2 and #4 cylinders. The problem
started with difficult starts in the mornings (I live in
Hawaii...don't think this counts as a cold start) and it would be
even more difficult to start after being parked in the sun for a while.
After getting started, it would idle really rough - like it is doing
full time now- but would eventually start idling normally after about
15-30 seconds.
The problem got progressively worse with the strong fuel odor at each
attempt to the point where it would not start. After noticing a leak
around the injector for the #2 cylinder, I salvaged 4 jets from a 92
Accord soaked them in Fuel injector cleaner for a couple hours and
fitted them to my 93 Accord. Now It is still very hard to start, and
when it does, I can take off the #2 and #4 plug wires and it will not
make a difference in the way the car idles (rough).
I changed the spark plugs/ wires, distributor cap, rotor all within
this month, though I have noticed a gouge in one of the contact post
inside the distributor cap.
Can anyone offer some insight on how to overcome these issues?
I have soaked the 4 original injectors in injector cleaner and I am
thinking about putting them back on, however after fitting the
straw-like nozzle from a can of compressed air over the needle like tip
at the bottom of the jets in attempt to blow out any residual cleaning
solution, I realized the air passed freely through two of the jets but
did not through the other two. Should I be concerned about this?
Thanks
Rasta
maroongrad
07-06-2006, 11:10 AM
Be concerned. Sounds like they're clogged, and a soaking in cleaner wasn't enough to get the gunk out. You'll either need to find a way to clean the inside so those two can start injecting again, or get some new ones. Based on the gas smell, I would have thought they were getting gas into the engine but it wasn't igniting. Clogged filters or injectors would absolutely make the cylinder stop working...not sure how to clean out the inside of them if a soaking and compressed air isn't working though.
