can i bypass theThrottle position sensorgatsales02 06-28-2006, 11:00 PM Does anyone know if you can bypass the throttle position sensor on a 87 4 cylander eldiablo1100 06-28-2006, 11:03 PM no, you need to replace it if it's bad. 4Wheel 06-29-2006, 05:05 PM Depending on you reasons for by passing the sensor it can be adjusted. All that is needed is a set of feeler guages an ohm meter and the FSM procedure. It is as simple as setting the dwell on points. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
