93 lumina dies while in idle or at stoplights
josepht81779
06-27-2006, 10:15 AM
It will quickly start back up and go until i take my foot off the gas again. I took it to the mechanics and they said that there is no codes for the problem.Has anyone had this problem that could shed some insight? starts fine runs for about ten minutes and then dies when no gas is being applied, ie..at stoplights or even when coasting. i have had the low coolant indicator light on but it has been checked and filled. 93 lumina v6 automatic sedan
jeffcoslacker
06-27-2006, 01:04 PM
Ususally an indication of overly lean idle mix...I'd check for vacuum leaks, stuck IAC or EGR, PCV, etc.
Supergumby
06-27-2006, 01:11 PM
If the ECM has lost power for any reason - dead battery, bad alternator, Etc., perform the 'Idle Relearn' procedure......See the sticky on the top of the main page.
dennisinmo
06-29-2006, 01:33 PM
This is a reply I did for another similar question for a 92.
My son had a 93 Z34 that ran great till about 90kmiles. Then it would start dieing after it got warmed up. It would mostly do it as he slowed down to stop or turn a corner. We replaced almost every sensor on the motor. Finally discovered it was the “phantom stalling” problem of the Z34. The fix was a set of injectors that were different than those furnished with the car. They were hard to locate. Had to get them from a dealership. Go to 60degreev6.com and search with the word phantom. Good luck. Someone on that website said you have to enjoy working on cars to own a Z34. I believe it.
josepht81779
07-06-2006, 08:33 PM
Thanks for the help!~!! :icon16: the IAC valve is the culprit. i gave in and just took it to the mechanics... 200 dollars later you folks are right. i spent 65 dollars for diagnostics that gave me the same answer that i got off of this forum...anyway thx for the help thread can be closed now.
rtom1
09-23-2006, 12:33 PM
what is the IAC valve??
