OBDI/OBDII/CAN Code ReadersBrian R. 06-21-2006, 12:47 AM Anyone have any informed opinions on good quality OBDI/OBDII/CAN code readers that are good buys for the money? I don't want to pay more than $400. Hooking up to a PC is good, but not necessary. I have a recommendation for AutoXRay 6000. Any opinions about others? Is this one a good buy, considering it has the PC software for graphing, etc. which I might use? BlazerLT 06-21-2006, 02:45 AM Anyone have any informed opinions on good quality OBDI/OBDII/CAN code readers that are good buys for the money? I don't want to pay more than $400. Hooking up to a PC is good, but not necessary. I have a recommendation for AutoXRay 6000. Any opinions about others? Is this one a good buy, considering it has the PC software for graphing, etc. which I might use? Do you need to read live data or just stored codes? Brian R. 06-21-2006, 11:41 AM I want to monitor live data - computer hook up is good. BlazerLT 06-21-2006, 12:44 PM You might as well go with this one. http://cgi.ebay.com/ebaymotors/AutoEnginuity-OBDII-OBD2-Windows-Scan-Tool-Scanner-USB_W0QQitemZ4652912665QQihZ002QQcategoryZ43989QQr dZ1QQcmdZViewItem Best out there. Brian R. 06-21-2006, 01:53 PM I need a stand-alone scanner which may be hooked up to a computer. I don't currently have a laptop with which to connect this unit. Might buy one in the near future though. BlazerLT 06-21-2006, 02:35 PM Even on ebay you won't be able to get even a used scanner for US$400. Check out ebay for mt-2500 and you will see some good options, you might luck out and grab one up for cheap. ZL1power69 06-21-2006, 03:08 PM i use an actron scanner. it reads any gm/chrysler/ford from 82-present. its awsome. http://www.actron.com/product_detail.php?pid=16143 Brian R. 06-21-2006, 04:31 PM I have to read Japanese cars. dmbrisket 51 06-21-2006, 11:29 PM if you wanna read forign cars live dada be ready to pull out about 3k, ive yet to find a useful forign/domestic scanner for less Brian R. 06-21-2006, 11:40 PM Maybe scanner is the wrong word for what I'm looking for. I want to obtain freeze-frame data in the unit and being able to plot live data on a laptop is desirable, but not necessary. blazes9395 06-21-2006, 11:45 PM The auto x-ray, in my opinion, is the most cost effective, upgradeable, versitaile unit you can buy. I have the autoxray 2000, upgraded unit to have live data scanning, readiness tests, freeze frame information. The 6000 is the one I am looking to get soon. It's capable of supporting domestic and import models, and can be connected to your pc for upgrades, and information can be downloaded from your unit to your PC. All for about $500.00 Brian R. 06-22-2006, 10:48 PM I'd like to get some more feedback. Thanks for the info up to this point. :) MT-2500 06-23-2006, 11:10 AM I'd like to get some more feedback. Thanks for the info up to this point. :) Brian A lot of people have gone to laptop soft ware. But to read obd1 obd11 and can you will need a high end scanner. Snapon MT-2500 is one of the better all around scanners. I have used one for over 20 years. Never wears out or becomes obsolete But the updates and new cartiages and can adapters will cost.:grinyes: :rofl: For just for obd11 Auto Xray is not bad. I use the ez link auto Xray for a backup scanner. Not sure if they have gone can yet. They say the 6000 auto Xray is a good one to. Good obd11 import and domestic coverage. www.autoxray.com Also bat auto tool store has some scanners and reviews and articles on them. http://tools.batauto.com/ http://www.troublecodes.net/articles/ Also you can run a post in the general forum on bat auto and ask about scanners. Good Luck MT MT-2500 06-23-2006, 10:00 PM I'd like to get some more feedback. Thanks for the info up to this point. :) here ia anothe link you might check. http://www.troublecodes.net/articles/Carcoderview.shtml Good Luck Brian R. 06-23-2006, 11:46 PM I can get an AutoXRay 6000 for $400 or so and it does the ODBI/OBDII and CAN out of the box - at least that is what is advertised... The Carcode OBD-II PC-Based Scantool that you referenced is very tempting, but I don't have a laptop (currently) and I don't want to buy one just for this purpose. I need one that is stand-alone with (maybe) the option for connection to a laptop. Very interesting, though... Thanks for the references. MT-2500 06-24-2006, 09:48 AM I can get an AutoXRay 6000 for $400 or so and it does the ODBI/OBDII and CAN out of the box - at least that is what is advertised... The Carcode OBD-II PC-Based Scantool that you referenced is very tempting, but I don't have a laptop (currently) and I don't want to buy one just for this purpose. I need one that is stand-alone with (maybe) the option for connection to a laptop. Very interesting, though... Thanks for the references. You are welcome The AutoXRay is a good scanner. Good price And if it is can ready more good on it. The old EZ link I have does have some pc based stuff with it and can be updated threw the pc. Good luck MT jbarsalou 06-26-2006, 11:35 PM Can the Autoxray help interpret the data? I borrowed a cheaper data logger and was almost useless because I don't know what the correct values should be of sensors. I see that the MT2500 is availible pretty cheap on ebay. Is this a good troubleshooter and also is it user friendly enough to figure out without training? What accessories are required for diagnosis for our blazers (mine is a '97). Brian R. 06-27-2006, 01:18 AM Can the Autoxray help interpret the data? I borrowed a cheaper data logger and was almost useless because I don't know what the correct values should be of sensors. If you consider the wide variation in sensor output between models and years, it is very difficult to have built-in a reference for the correct values of the sensor outputs. I rely on the manufacturer's maintenance manuals for that information. Consider the variation possible in the Engine Coolant Temperature sensor just by changing the thermostat. Some are very predictable because they switch battery voltage on or off. I don't see how you could get them all correct though. Brian R. 06-29-2006, 01:21 AM What are personality keys for a Snap-on scanner? Brian A lot of people have gone to laptop soft ware. But to read obd1 obd11 and can you will need a high end scanner. Snapon MT-2500 is one of the better all around scanners. I have used one for over 20 years. Never wears out or becomes obsolete But the updates and new cartiages and can adapters will cost.:grinyes: :rofl: For just for obd11 Auto Xray is not bad. I use the ez link auto Xray for a backup scanner. Not sure if they have gone can yet. They say the 6000 auto Xray is a good one to. Good obd11 import and domestic coverage. www.autoxray.com (http://www.autoxray.com) Also bat auto tool store has some scanners and reviews and articles on them. http://tools.batauto.com/ http://www.troublecodes.net/articles/ Also you can run a post in the general forum on bat auto and ask about scanners. Good Luck MT MT-2500 06-29-2006, 09:58 AM What are personality keys for a Snap-on scanner? They are keys for the OBD11 adapter. The keys are for different makes of cars that plug into ans set the obd11 adapter to read different makes. Like ford GM CRY and Different imports. There is about 15-20 different ones. MT 93LT 06-29-2006, 09:58 AM I have the AutoXray 6000. It has been a most valuable tool. I especially like being able to view the live data as the vehicle is being operated. With that information, having no codes to go by, I was able to determine my O2 sensor was failing rather than my EGR valve, just by watching the values in various situations. You can store data on the Xray 6000, as well as the 5000 and 4000 which are identical with features disabled. For the money, if you want all features available and all the cables to connect to all the cars in one box, then the 6000 is the only logical choice (as for as AutoXray is concerned). If a person does not need OBDI out of the box, or at all, then the 5000 is for you. It is CAN ready and OBDII compliant with all cables. No OBDI cable, or ability to read it with out calling AutoXray and paying a small fee for the code to activate OBDI plus the fee for a OBDI cable. The amount of data these scanners can hold is very small, which is one of their draw backs. You have the ability to set the frequency in which it records the data to store, i.e. half second, second, two seconds, five seconds and so on. At the hald second interval, you can capture about 18 seconds worth of data. At the second interval, you get a little over 30 seconds worth of data. And, you can only have one stored data value. This is why the scanner is the price it is instead of 700 to 900 bucks. The live data is what will be most useful to you. I seldom use the stored data feature much less transfer it to the PC. I bought mine on Ebay, came with the EZ Charge 200 for 429.00 and free shipping. It also had a 20.00 rebate, which took about 6 months to get:). The neat thing about my scanner is it had the very latest firmware revision, which has been determined to be incompatible with the EZ charge 200, so I cannot use it. My choices are to send the unit to Autoxray and they will burn new firmware in to correct the problem with compatibility or not use the EZ Charge 200. I chose not to use the EZ charge 200. The scanner has a back light feature which is nice, and necessary when using it in the dark. I just wish it had a dedicated button to turn it on and off. You have to go through the menu to do this, and that light will help eat the batteries pretty fast. Without the light on, the batteries last forever, or at least seem to. westsider 06-30-2006, 05:59 PM I also have an autoxray 6000 and it is a great scanner. It will do more than enough for most people. The only thing that I would like it to do is bidirectional control but it doesnt. Other than that it is great. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
