hi pitch noise on the power steering pump
gelcol
06-21-2006, 12:36 AM
I sprayed some w40 on the side of the pully and the noise is kinda change to low pitch sound .like grinding metal bearings, how can I make the noise go away?
jeffcoslacker
06-21-2006, 12:46 AM
Serp belts will hiss or whistle when glazed, then chatter or rattle when you slick 'em up like that...either replace the belt or make sure it's not running out of line with the other pulley, like if the mounting bolts are loose...
gelcol
06-21-2006, 12:59 AM
thanks for the responds mine got a metal gringing sound I suspect its a bearing behind the pully.
gelcol
06-21-2006, 10:44 AM
on the 3rd day its sounds like a remote control aircraft.
gelcol
07-24-2006, 02:45 PM
noise found on the Alternator bearing got replace noise disappears.:grinyes:
