auto trans 2cnd gear shift
Google
Web AF
liveinusa
06-19-2006, 10:00 PM
95 safari 4.3 automatic trans
takes off ok but when It shifts into second gear
@ abaut 18 miles hour feels like trans winds up then gives
a big jump any help please thanks Sal.
Kings-x59
06-19-2006, 10:16 PM
first thing to do is check the transmission fluid level with the engine warmed up and the running. what you describe indicates a slow pressure build in the transmission. I believe the '95 has the 4L60E transmission. this transmission is similar to my 700R4, but electronically controlled.
Has the transmission fluid and filter ever been changed?
liveinusa
06-20-2006, 06:46 AM
thanks for fast reply Kings.
I bought van with 125.000 miles changed the fluid and filter then
it now has 170.000
MT-2500
06-20-2006, 11:02 AM
it now has 170.000
Well is the fluid level good?
How does fluid and filter look?
Any check engine lights?
Is the egiune running up to par?
Does it have all 4 forward gears or just 1 and 2?
Have you scanned for codes?
MT
liveinusa
06-20-2006, 10:10 PM
boy you now your stuff ............
I took a peak at the trans fluid and it is low
tomorrow I will pick up a trans filter, and new fluid
and hope that will do the trick thanks will post back with results.
Kings-x59
06-22-2006, 12:06 AM
and to back up MT's post.
how does the fluid look? is it red, or brown or..yikes.. black?
siphon some out through the dipstick tube into a glass jar and check it out.
if it's black you have burned clutches or a burned band.
Blue Bowtie
06-22-2006, 10:06 PM
Good thing a 4L60 rebuild is fairly easy.
http://72.19.213.157/files/4L60ETeardown.jpg
Kings-x59
06-23-2006, 09:54 PM
Is it just the photo Blue? or is that band burned?
I toasted my 700R4. What I found was the 1-2 acumulator spring broke, rev'ed it too high and burned the forward clutches. Picked up a few special tools and rebuilt it. Easy..yes. If you can follow directions..really well.
I never dismantled and rebuilt something so complex with so few tools.
Blue Bowtie
06-24-2006, 03:47 PM
I think it must be the photo, and/or the color rendition of the fluorescents I use in the garage (I mix "cool white" and "warm white" lamps to get better overall color spectrum). You're probably seeing the orange/yellow tint of those lamps, since that WAS a new band going into that trans. That was 20,200 miles ago, and it's still doing fine.
Google
Web AF
