Air conditioner fuse question 92 Camry
Google
Web AF
jim11787
06-17-2006, 02:10 PM
Sorry to ask such a basic question, but can anyone direct me to the 10A fuse location in a 92 Camry. The A/C stopped working (blower works, AC clutch does not engage), but I have not been able to find a fuse marked for air conditioner. The wiring diagram shows a 10 amp fuse that could cause this problem. I do not have the manual that came with the car.
Thanks in advance.
Mike Gerber
06-17-2006, 04:01 PM
There is a generation 3 manual stickied at the top of this forum. It should have the information you are looking for. There is an entire air conditioning section. It is section a/c.
Mike
jim11787
06-17-2006, 08:05 PM
Mike-
Thanks for helping a newbie. I checked it out and it looks like the fuse is on the passenger side. I'll try it tomorrow morning.
Jim
imc188222
06-29-2006, 10:41 PM
The air conditioning system has one fuse and one relay. They are number 13 and number 31 both in the passenger side kick panel. The most likely problem for you ac compressor clutch not engaging is that you system has leaked. There is a low pressure switch in the system that will keep the compressor from running if enough freon leaks out. hope this helps
Google
Web AF
