Vacuum Line Help...97 3.1 Lumi
Myxlplyxxx
06-16-2006, 11:07 PM
Well the A/C system now works(thnx Richtazz) and is blowing cold air BUT,... The vents didn't work SO... I cked all the vac-lines and sure enough the line from the vac-ball to the "T" was shot(a large hole in it) so I pulled the line and the vac-ball out... removed the broken end...stuck the(now shortened) vac-line in the vac-ball and "PooF" like magic all the vents now work and go where I set the controls ... the problem is I need about 6 ft of that (plastic Line) and autozone nor murrays has it...(all they got is rubber which will collapse)... I will try napa, carquest and pep boys tomorrow to see if I get lucky but if not.... more than likely a dealer thing??? Any other ideas where I could get this stuff???:banghead:
Thnx in advance,
MYX
tblake
06-17-2006, 12:15 PM
if you get the thickwalled rubber it till work. Ilso what you can do is reuse the old plastic one by slipping both broken ends into some rubber line.
Myxlplyxxx
06-17-2006, 10:47 PM
I got a hold of some 3/16th(had 1/8th) vac-line and replaced the section from the Vac-ball to the "T" its a lil thicker but it did the job... BUT... after a short ride to ck' everything out... I realized Im losing a fair amount of air again(only when I gun it or accelerate harder than a trickle) from the dash vents to the floor and window again... about 40-50%...(it comes back once I get outta the throttle)It was working perfect for a lil' bit... SO back out tomorrow to ck' ALL the other vac-lines... Im guessin(and it figures) it will be the one to the inside of the damn car(thru firewall) since I had the one from the Plenum off and cked it...(SOLID) so we will see tomorrow....
MYX
jeffcoslacker
06-17-2006, 11:13 PM
An air line set for airshocks would be cheap and the right stuff...
kyle3
06-21-2006, 04:20 PM
Where is the vacuum ball located on 97 lumina
richtazz
06-21-2006, 05:08 PM
The actual vacuum ball itself may be bad. I've used rubber line to repair that plastic line and never had an issue. It's a storage container to keep steady vaccum when the engine isn't producing enough (like at WOT).
