trouble codesmayito 06-16-2006, 03:20 AM I have 2003 v6 silverado recently converted to a v8 5.3. I'm getting several trouble codes, can someone tell me how to fix them. 1.) PO455- Evaporating Emission System Leak Detected (i have a feeling its the gas cap) 2.) PO480 Cooling fan relay 1 control circuit - PO481 same as PO480 but relay 2. I have cleared the codes but they still come on. Also tried disconnecting the battery too! Everything works fine the check engine light is starting to get to me. jethro_3 06-16-2006, 11:02 AM Who did you get your PCM from???? Did you do the swap yourself? PM me for more info.... gmtech79 06-16-2006, 10:09 PM Are you using elec fans or mechanical?? Just something we need to know about when the swap was done mayito 06-16-2006, 10:23 PM The fans are mechanical. gmtech79 06-16-2006, 10:25 PM well there is the answer to p0480 and p0481, you have a pcm that was once made for use with electric fans and now since there are none it will set the DTC's. mayito 06-16-2006, 11:15 PM The guy said he could not make the electric fans work, so he put a mechanical fan. He has had this problem with other trucks when a v6 was swaped for a v8 with electric fans. I forgot to mention this. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
