Removing paintnick1990 06-14-2006, 03:37 PM Whats the easiest way to remove automotive paint from plastic? The paint is enamel. xpeed 06-15-2006, 08:05 PM Just sandpaper it. thaidiecast 06-16-2006, 11:04 AM Brake Fluid is easy way to remove paint but it's dangerous for your skin if you contact it directly, You must use handglove. Nail Paint Remover or Acetone is more safety and more convenience because you can contact it directly. But it can remove only enamel paint. If you want to remove other type colors (Acrylic,Lacquer,etc.) You should use Brake Fluid or sanding paper. GTmike400 06-16-2006, 11:41 AM Nail Paint Remover or Acetone... Acetone melts plastic. nick1990 06-16-2006, 06:45 PM Nail paint remover ?? Is that finger nail polish remover vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
