does it hurt the spark plugs to gap a little biggersilver100 06-10-2006, 09:33 PM my truck says to gap the spark plugs at .035 but i was told by a parts guy that you can gap the plugs at .40 to increase the spark , i didn't know if .05 would hurt the plug . i also run a hotter plug in my truck also . it calls for a r43ts ac delco and i run r45ts ac delco it seems to help the gas mileage . but i was going to try the bigger gap but thought i would check with you guy's first to make sure there it would not hurt anything . thanks silver100 :grinyes: MT-2500 06-10-2006, 10:54 PM my truck says to gap the spark plugs at .035 but i was told by a parts guy that you can gap the plugs at .40 to increase the spark , i didn't know if .05 would hurt the plug . i also run a hotter plug in my truck also . it calls for a r43ts ac delco and i run r45ts ac delco it seems to help the gas mileage . but i was going to try the bigger gap but thought i would check with you guy's first to make sure there it would not hurt anything . thanks silver100 :grinyes: Well is that parts guy a certified tech or one of the auto zone counter mechanics? :grinyes: :lol: :rofl: You are all ready 2 numbers to hot why are you trying to go hotter? If you get it to wide and to hot you will burn a hole in the piston. Stick with the gap and the plug it calls for. MT Mr. Smith 06-13-2006, 09:34 PM my truck says to gap the spark plugs at .035 but i was told by a parts guy that you can gap the plugs at .40 to increase the spark , i didn't know if .05 would hurt the plug . i also run a hotter plug in my truck also . it calls for a r43ts ac delco and i run r45ts ac delco it seems to help the gas mileage . but i was going to try the bigger gap but thought i would check with you guy's first to make sure there it would not hurt anything . thanks silver100 :grinyes: Don't listen to the parts clown. The gap grows wider as the plug wears. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
