93 lumina wont stay started
biggerrickey
06-09-2006, 01:15 AM
i will go for a little while and it just dies. ive read alot of the other story just want to know if anyone has had the same problems. fuel pump is good just put fuel filter in. no change yet.
richtazz
06-09-2006, 10:20 AM
Any Check engine light? have you checked fule pressure? Do you have spark when it dies? We need a little more specific info to help you narrow it down.
biggerrickey
06-09-2006, 11:25 AM
engine light comes on and then goes off. its firing but it wont stay runnig. i can drive for about 5 min than it pudders and shuts off. like its not getting any gas.
richtazz
06-09-2006, 11:44 AM
The first thing you need to do is get a fuel pressure tester and check fuel pressure at the rail. It should be 31-35psi minimum, key on/engine off.
josepht81779
06-27-2006, 10:22 AM
did you find out what is wrong with your vehicle? mine has the same problem. if you did please let me know
