95 threw PO441 code
Google
Web AF
ZL1power69
05-31-2006, 10:22 PM
yesturday the SES light came on. i reset the ecm because i get a PO400 once and a while and figured thats what it was. well today, the light came back on again. i threw a scanner on it and it came back with P0441 - Evaporative Emission Control System Incorrect Purge Flow. i cleared the code and on my way home from work tonight, it came back on again. This is the first time the truck has thrown this code. anyone know what could be causing this problem? one thought was that the gas cap was not secure but it is tight. i would appreciate any suggestions.
wolfox
06-02-2006, 12:16 PM
Re-tighten your gas cap. 3 clicks is all it takes. :) But seriously, having already checked that, it could be a number of things...to include tank balance valves, a rotten piece of rubber tubing or worse yet...
You're one of those peple that keep clicking the handle on the gas pump after the first time it stops.....
Excess fuel at the top of the tank in areas meant for vapor can suck raw gas up into recovery canisters and the like. When the canister sucks in fluid rather than vapor, it can be slightly less than cooperative for a while... erm until it basically dries out.
DINO55
06-02-2006, 02:07 PM
Hey ZL1POWER69.
If you ever figure out what's throwing out that P0441 code, Post the answer please.. I have been fighting this problem on my son in law's 97' Blazer for 6 months with no freaking luck.
Thanks, Dino
MT-2500
06-02-2006, 02:54 PM
That one is a little more that a gas cap.
Hit me with a e mail crunch@troublecodes.net and I will e mail you a pdf on the repair flow chart for it tonight when time permits.
Strange on the codes 400 code is for a Z engine and code 441 is for a w code engine 4.3
Is yours a W or a Z engine. Did the code 400 only come up one time?
MT
ZL1power69
06-02-2006, 08:32 PM
gas cap is completely tight, always. and yes, i have been known ocassionally to bump the total up a few more cents after it clicks off. it has never thrown that code before yesterday though and has come on 2 more times since creating this thread.
MT-2500
06-03-2006, 12:02 AM
Hey ZL1POWER69.
Thanks, Dino
DINO55
Are you sure about the code no P0441?
A 97 does not show a code 441 code on it.
MT
DINO55
06-03-2006, 12:10 AM
My Mistake MT-2500
Turns out it was a P0446 code
Thanks for refreshing my memory.........
BlazerLT
06-03-2006, 12:47 AM
I found even though my gascap was tight, it was binding and not tightening all the way.
I put a bead of light grease on the threads and it goes all the way tight now.
When it binds, it will click but won't be tight at all.
Also, did you just fill the tank before this happened?
ZL1power69
06-03-2006, 01:34 AM
yea filled the tank maybe 2-3 days before the light started comin on. i always turn the cap till it clicks and it has never set a po441 until this week.
BlazerLT
06-03-2006, 02:01 AM
Just to let you know, only fill on low until it clicks off.
Overfilling the tank will put fuel into your EVAP system and cause the problems you are seeing.
The vent for the EVAP system is 2-3 inches below the top of the fill pipe.
MT-2500
06-03-2006, 10:28 AM
My Mistake MT-2500
The code P0446 is a canister vent solenoid code. But could be caused by several things.
If you need the repair flow chart in a PDF give me a e mail crunch@troublecodes.net
ZL1power69
06-03-2006, 12:40 PM
so it will eventually dry out?
Google
Web AF
