99 tranny prob
Google
Web AF
pokergypsy
05-31-2006, 05:25 PM
hi i got a 99 gp 3.8 and the tranny shifts 1 to 2nt good 3 to 4th takes long ?the ses light came on 1 time and it shift rought 1to2nt but the light went off and 1to2nt fine but the 3rd to 4th still takeing long?
BNaylor
05-31-2006, 06:52 PM
Sounds like you need to get it scanned with a trans capable scanner. Even though the SES light is not staying on the PCM will store tranny fault codes for retrieval. Rough and delayed shifting could be the pressure control solenoid (PCS). A DTC error code of P1811 max. adapt/long shift may be stored.
When did you have a tranny service last performed like replacing the ATF and screen filter?
troy1
05-31-2006, 10:56 PM
PCS is what I'm thinking they are coming out of the wood work with this warm weather.
Troy
98BlackTransAm
05-31-2006, 10:59 PM
i had the same problem from 2nd to 3rd for a couple weeks when i had my 3.4 grand am,, never had it diagnosed but the problem just went away on its own.:dunno:
BNaylor
06-01-2006, 09:58 AM
Troy
Yeah, especially down here. We hit 102 degrees last week. I helped two guys in our local GP club diagnose suspected PCS problems. $525 with part at the new Cottmans. Same old story. :shakehead
SNKPWR
06-01-2006, 10:26 AM
lately mine has been acting up a little when it gets hot out...mostly just when i've been driving for a while...if i floor it at about 25, it normally just downshifts to 1st, and accelerates, but lately in the heat, it will downshift, then the revs will shoot up, and oscillate, like bouncing off the rev limiter, then shift to second...any ideas?
Google
Web AF
