Extreme heat under hood????
Google
Web AF
bigdawg703
05-30-2006, 07:49 PM
I just bought a 2002 crew cab 4x4 and I have noticed that it gets EXTREMELY hot under the hood after just running for a few minutes.... I'm talking burn your hand when you open the hood hot..... I was just wondering if this is a normal thing with the 4.3L?
OverBoardProject
05-30-2006, 10:34 PM
You really aren't suposed to ask the same questions on both the Chevy forum and the GMC forum.
You'll probably get the same answer on either forum.
The answer to your question is NO, these motors don't get that hot.
You might want to get teh Fan Clutch checked. Flush the cooling system.
And of course flush the transmission and change the filter. I'll tell you how to change that oil where you asked.
You will also want to change the oil, and I sugest doing a good tune up.
A tune up will probably take care of your hesitation problem.
blazee
05-30-2006, 10:41 PM
OBP is right, you're only allowed to ask your questions once. Because they were answered here, I'm removing the ones from the Sonoma forum.
bigdawg703
05-31-2006, 06:14 PM
Sorry I wasn't getting a reply on the GMC forum so I figured I would have a better chance on the s-10 forum, I want post in both again tho...... thanks for the answers
OverBoardProject
05-31-2006, 08:13 PM
No worries, everyone makes the odd mistake. And the only way to piss Blazee of is do the same thing over and over again (Unless it's a real a$$)
BLAZERBOY69
06-01-2006, 02:49 PM
Back To Your Question Though, Also Replace Your Tstat. On My 84 S10, I Had The Problem Of It Heating Up Real Bad, And I Was Told To Replace The Tstat. When I Pulled Off The Rad Hose, I Found It Had No Tstat At All(bought It In Southern Il)! Put It In And Found It Working Much Better
Google
Web AF
