96 blazer 4x4 electronic shift to Neutral???cmadmaxman 05-29-2006, 05:18 PM I'm looking to buy a this blazer, but need to shift to neutral in the transfer case for pulling behind our moter home. Is there a way to make this electronic button shift do that? Thanks for any help. I have tried searching, but no luck so far. muddog321 05-29-2006, 05:38 PM If your year has that capability the buttons should be marked with a neutral light. On 98up when you are in 4Hi you push 4HI and 4Lo button at the same time for 10 sec with trans in neutral and it puts the xfer in neutral. Then shift to reverse for 1 sec then drive for 1 sec then turn ign off. Put in park and you are in neutral and can tow. Straight out of the98up book. cmadmaxman 05-29-2006, 06:17 PM No neutral light! I have seen the neutral light you speak of on the newer blazers and s-10. MT-2500 05-29-2006, 06:35 PM I'm looking to buy a this blazer, but need to shift to neutral in the transfer case for pulling behind our moter home. Is there a way to make this electronic button shift do that? Thanks for any help. I have tried searching, but no luck so far. If you tow it pull your drive shafts. Even if you do find a neutral on it with the drive shafts hooked up you will be spinning some gears in there. Better to be safe than sorry. MT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
