Does anyone know what other engines
Google
Web AF
nuwt
05-24-2006, 05:33 PM
Does anyone know what other motors will bolt up to a 4 speed manual transmission for a 84 s10? Would like to get bigger motor since I can't seem to find a 2.8L manual fuel pump engine with paying an arm and a leg.
dmbrisket 51
05-25-2006, 02:09 AM
i belve a 3.1 and a 3.4
OverBoardProject
05-25-2006, 03:17 AM
DM is absolutely correct.
You'll need an electric fuel pump, along with a carburated intake manifold.
You'll also (probably) have to get your flywheel re-ballanced to 0 degrees.
You might also need to use your oil pan and oil pickup, although I don't know about the oil pan bit on a 2wd.
OverBoardProject
05-25-2006, 09:05 PM
Just a couple of links that I was too tired to give you last night
http://s-series.org/content/view/18/1/
http://www.off-road.com/jeep/cherokee/xjtech/engine/28-34swap.html
http://users.spec.net/home/emxjc/
Blue Bowtie
05-25-2006, 11:25 PM
A good used transmission that fits an SBC is pretty cheap, by comparison.
nuwt
05-28-2006, 01:40 PM
I do believe this is the easiest and cheapest route for me.
Thanks everyone for the info!!
any ideas on which manual transmission to use for a small block, or convert to an auto?
OverBoardProject
05-28-2006, 02:20 PM
You'll get better economy with a standard, so that's 1 thing to look at
nuwt
05-29-2006, 03:25 PM
Has anyone ever put a sbc with manual tranny in a S-10? If so was there any major problems? I have seen alot of auto swaps, just never a manual swap.
OverBoardProject
05-29-2006, 08:39 PM
Personallyb if I was doing a V8 conversion I would just grab the entire drivetrain from a 5 or 6 speed Comaro, and bolt it all in. Including the transmission.
Then you have 1 fun to drive, bad ass truck!
nuwt
05-29-2006, 09:29 PM
Since my truck is carb. what year would I havre to go back to as not get anything that requires a computer? My S 10 is vacumn advance and does not have any computer. Early 90's?
OverBoardProject
05-29-2006, 09:34 PM
If it was me I'd buy a newer 350 model, and just switch to a carburated intake manifold. There are so many parts available for them that you'd be suprised.
Avoid any nade between 71 and the mid 80's since they are low compressin slugs compaired to the others.
nuwt
05-29-2006, 10:28 PM
Kewl!! Thanks!!!
dmbrisket 51
05-30-2006, 04:29 AM
b4 you get crazy with that, why a stick? from what ive come across youll run into a lot more problems with a stick then an auto, and theres so much power there that you dont need a stick for it to be fast, hell a stick behind a 4.3 feels like a 350... and when you decide what your going with make sure your carb intake will bolt to that set of heads, and if not, if someone makes one for it
nuwt
05-30-2006, 08:49 AM
The main reason is my truck is already a stick and I don't want to swap out column, or find a shifter to put in floor.
OverBoardProject
05-30-2006, 11:41 AM
Personally I think that a stick is funner to drive any day of the week.
When your done I'd love to take that monster out for a spin, preferably around a track.
nuwt
05-30-2006, 12:25 PM
This project is still in the planning stages for now. Got 2 Dodges infront of this one. I wish I was driving my truck tho. I am a Chevy man, just got A neon and a Charger that is in need of attention first. But I will keep you posted as to the S 10 project.
Google
Web AF
